Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 05-15-2023, 07:36 PM
rupee rupee is offline
Default Sync X with Pro Tools Carbon: possible options?
Hello,
I currently own a Pro Tools Carbon as my interface.
I find myself recording and editing to picture more frequently nowadays.
Is the following something that can be done?
If I connect a Sync X to my computer via HD native thunderbolt (2013 Mac pro trashcan) then connect the Carbon WC in to receive from Sync X.
Any advice on this would be appreciated.
Thanks in advance!
Old 05-15-2023, 07:58 PM
BScout BScout is offline
Default Re: Sync X with Pro Tools Carbon: possible options?
The Sync can run standalone as a master clock. And you can hook clocking to the Carbon.
But, you either are using the HD (HDN) selection in playback engine or you are using the Carbon. Can't use both inside Pro Tools. And Pro Tools won't talk to the Sync unless it is set to HD (HDN) -- and then you need an interface hooked to the HD Native thunderbolt box's digilink connectors (or you can't select it in the first place.)
But most importantly, what exactly do you think the SyncX brings to the table with picture? Unless you have a genlock system (video output that accepts tri-level sync), it does nothing for picture accuracy. Just hooking a SyncX or SyncHD does nothing for video playback in Pro Tools as a masterclock. All the devices that need to run frame edge sync need to also be able to accept genlock.
Pro Tools Ult 2023.9, HDX 3, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, FireHD x 2, Dock, iPad Mac Mini 14,12, 12 core, macOS 13.6RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 05-17-2023, 10:33 PM
SonicSloth SonicSloth is offline
Agreed with Bscout - I don’t think you’re helping yourself here. Unless you’re using an external video peripheral that accepts video ref, the Sync X will just be a very expensive black box in your rack.
Old 06-29-2023, 06:31 PM
filmixer filmixer is offline
If you want frame edge, sample accurate sync, you need to use Digilink. Same thing with the Thunderbolt 3 interfaces. No frame lock.
Mark Ettel C.A.S.
Old 07-21-2023, 06:32 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
For frame edge sync you must have your HDn or HDX card (only these exclusively) connected via serial cable to the Sync HD or Sync X host serial port.
See the picture for example connection.
*Note: at the moment there are no other cards working with within PT at the frame edge occurrence.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2023.6 Ultimate ● macOS Ventura 13.5
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.6.9.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
More Carbon Sync Issues...Must Get Solved... tomhartman Pro Tools | Carbon 88 03-25-2023 10:24 AM
Sync Timecode in Carbon with Akai Supremesoundz Pro Tools | Carbon 0 12-19-2022 11:15 AM
Sync Problems with Carbon Downstream tomhartman Pro Tools | Carbon 7 07-01-2021 02:15 PM
Using Carbon with Avid Sync HD? akhafaji Pro Tools | Carbon 1 01-18-2021 12:03 AM
