Old 05-06-2023, 04:27 AM
wickett wickett is offline
Default Intermittent bit crushed/severely distorted audio (SOLVED)
Hi I'm having issues with intermittent bit crushed/severely distorted audio on my mac. Sometimes I just get crackling.
The problem goes away when I change buffer size but reoccurs after a while.
I have an McDSP APB-16 and UAD Satellite 2 chained together on one thunderbolt port. The APB-16 is clocked to the carbon via word clock cable.
Old 05-06-2023, 06:58 AM
its2loud its2loud is offline
Default Re: Intermittent bit crushed/severely distorted audio
If you have error suppression enabled under the playback engine settings, uncheck it.
The digital garble should go away. You may get more frequent AAE error message but there might be something on your system causing those that you’ll need to 8nvestigate.
The Ignore Errors During Playback/Record option determines how Pro Tools responds to error re- porting from the Avid Audio Engine (AAE) during playback and recording
Enable error suppression only if you are experencing frequent errors that are interrupting your creative workflow. When error suppression is enabled, you can experience a degradation of audio quality. However, this may be acceptable in order to avoid interrupting playback and record- ing when working with instrument plug-ins.
Disable error suppression when you need to ensure the highest possible audio quality, such as for a final mix.
Old 05-06-2023, 02:42 PM
Thanks for the info. Ignore Errors During Playback/Record option was unchecked.
Just wondering what else to look out for on my system that could be causing it?
Old 06-08-2023, 07:48 AM
dif dif is offline
Hi
Did you find a solution ?
same problem here with APB
Thank you
Old 06-08-2023, 09:12 AM
Yes I had the Carbon checked in both carbon central and the Apple Audio Midi Setup>Network Device browser. You have to uncheck the unit in one or the other.
I found it in one of the Avid guides. Caused no end of hassle here.
Hope that helps.
Old 06-08-2023, 09:58 AM
dif dif is offline
I don't have a carbon but exactly the same problem (crackling distorted sound ) with HDX/HD I o
Thank you for your help
Old 07-17-2023, 06:41 AM
I got the problem again when using the new kd1 plugin. I think it’s programmed to utilise the higher bandwidth of the updated units. The support guy said they will be offering a thunderbolt upgrade in the near future so maybe this will help
Old 07-17-2023, 07:55 AM
dominicperry dominicperry is online now
You've got three really good, expensive systems working here, but I'm not really sure that they are meant to play together. You computer is having to funnel data off into and out of the Carbon, APB-16 and UAD Satellite as three separate tasks. If it works, it works, but I don't envy the troubleshooting if it doesn't.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.5.2, Pro Tools 2023.9, Carbon.
Old 07-17-2023, 09:40 AM
It has caused a lot of downtime and trouble shooting. It’s a shame because everything worked fine before. I will probably have admit defeat and get rid of one of the units.
Intermittent Ring-Modulated/Bit Crushed Playback of Recorded Audio AxiomDesignGroup Pro Tools HDX & HD Native Systems (Win) 8 09-03-2020 12:44 PM
During recording, audio sounds fine, during playback, it sounds bit crushed JJTaylor Pro Tools 11 16 03-08-2017 05:05 AM
Distorted sound (intermittent) on playback ProMan Pro Tools SE and Essential (Win) 17 08-15-2011 04:45 PM
8.0.4 bit crushed audio problem glideman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-26-2010 10:56 PM
5.1 - really severely uncool region bug destruktobot MIDI 0 07-28-2001 04:32 PM
